It sounds like you could have an issue with the idle air control valve (IAC).
It can be due to a dirty IAC can cause the vehicle not to idle. When a IAC gets dirty the air flow through the valve gets restricted. So the IAC cannot work as designed and the engine shuts off.
You can service the IAC by cleaning it out. Most cases this will improve the idle.
https://www.2carpros.com/articles/how-a-idle-air-control-valve-works
https://www.2carpros.com/articles/idle-air-control-valve-service
I have attached the diagrams for your reference.
Images (Click to enlarge)
Sep 16, 2021 at 5:55 AM
