2000 Mercury Mountaineer Replacing the Fuel Pump
2000 MERCURY MOUNTAINEER
94,000 MILES • 6 CYL • 2WD • AUTOMATIC
DARIUS2448
I need to find out how to go about replacing the fuel pump on the mercury mountaineer 2000. I also need to find out if this model has a fuel pump reset switch
Jan 8, 2010 at 10:45 PM
  • 110,240 POSTS
You need to remove the fuel tank to access the pump. As far as the reset, check in the rear of the vehicle behind the plastic covers on the side.
Mar 23, 2010 at 2:41 AM
