I am attaching the entire process below but here is a guide that will give a little more detail on how to remove these fan clutches:
https://www.2carpros.com/articles/fan-clutch-removal
The manual does not have a lot of detail so please review the guide above. However, below you will find the info from the manual that will show where to put a 3/8 ratchet and holding tool to hold fan in place while you are removing the nut.
This is not a reverse thread nut so it will come off the normal way (left hand twist).
Please run through this info and let us know what questions you have on this.
Thanks
Images (Click to enlarge)
Feb 25, 2022 at 11:11 AM
