2000 Mercury Mountaineer Fan was working on high speed only
2000 MERCURY MOUNTAINEER
216,000 MILES • 6 CYL • 4WD • AUTOMATIC
GRAVEY00
Fan on dash control panel or steering column was working on high only for some time and now has quit working all together. When working only on high I was told it could be a problem with the blower motor resistor but because it has climate control was a fairly expensive part. Didn't try to make or have the repair done even though it was all out heat or blasting cold but now nothing and it 80+ degrees. I need some air flow. Any help would be greatly appreciated
Jun 15, 2010 at 12:17 PM
RACEFAN966
  • 5,029 POSTS
Well you probably do have a bad blower motor resistor. Now if you have a digital multi meter then we can test it.
Jun 16, 2010 at 3:35 AM
GRAVEY00
I do have a digital multi meter - haven't used much and am by no means an electrical wizard but would like instructions to try to test to see if this resistor is bad
Jun 16, 2010 at 10:09 AM
RACEFAN966
  • 5,029 POSTS
Ok no problems you do know that at you local parts stores these are only around 22 dollars? Now with that I have included pics of the two types that are used on your truck. Look at them and let me know which type you have so I can walk you through the test ok.
https://images.2carpros.com/forum/automotive_pictures/249564_710285_1.jpg
https://images.2carpros.com/forum/automotive_pictures/249564_875496_1.jpg
Jun 17, 2010 at 3:51 AM
GRAVEY00
It closely matches the bottom picture
Jun 18, 2010 at 8:57 AM
RACEFAN966
  • 5,029 POSTS
Ok use the pic below. I need you to use you meter and check for power at the harness on the two larger terms. So unplug it and then turn key on engine off it fine and then set on low speed and check for power at one then turn to high and check for power on the other. Let me know what you find.
https://images.2carpros.com/forum/automotive_pictures/249564_875495_1.jpg
Jun 19, 2010 at 2:36 AM
