1999 Mercury Mountaineer Brake Lights
140,000 MILES • 6 CYL • 4WD • AUTOMATIC
JLA7335
Hello Im Having Break Light Problems I Checked All Fuse And All Bubls I Had The Third Break Light Working But Know I Replaced the break swich now none is working Im Very stumped Thank You For Your Help!!!!!!!!!
Nov 19, 2008 at 7:02 AM
  • 110,248 POSTS
Hi:
It they stopped after replacing the switch, there must be a problem there. Make sure the electric connection is tight and making connection. Also, follow the wires a few feet to make sure they are in good condition. Finally, check if there is power to the switch.
Let me know what you find.
Dec 15, 2008 at 5:16 AM
