Sometimes doesn't turnover to start. Acts like neutral safety switch is out of adjustment like on the older cars. I saw what must be it on this car on side of trans at shift cable. Adjust back and forth still nothing. Not a 2 wire fix. Where do I go from here?
SPONSORED LINKS
Wednesday, October 27th, 2010 AT 10:19 AM
MECHANIC
Hi billvivers@yahoo. Com, Welcome to 2carpros and TY for the donation
Check fuse no.22 and no.6 in the PDC if okay test the starter motor relay also in the PDC-let me know
Wednesday, October 27th, 2010 AT 10:27 AM
BILLVIVERS
MEMBER
The fuses are fine that you gave me to check. They actually have absolutely nothing to do with the start circuit on this vehicle. Fuse 24 (IP) and fuse 5 PDC apply.
SPONSORED LINKS
Friday, October 29th, 2010 AT 11:40 AM
MECHANIC
Sorry! I gave you the wrong info-fuse 5 and 24 applies, test the starter relay, DTR and ignition switch-
