1998 Mercury Mountaineer brake light switch
140,000 MILES • V8 • 4WD • AUTOMATIC
MIKEMLT
I just changed my brake light switch and start my truck, but it is lock in the park position I can't get it released. Help!
Jan 26, 2008 at 11:50 AM
BMRFIXIT
  • 19,053 POSTS
[quote:4e1c5a1a43="mikemlt"]Brakes problem
1998 Mercury Mountaineer V8 Four Wheel Drive Automatic 140000 miles
I just changed my brake light switch and start my truck, but it is lock in the park position I can't get it released. Help![/quote:4e1c5a1a43]
when you step on the brake do the brake light come on?
check fuses and also check the wires
in some cases when a car with remote starter
they cut into the brake wire with time that wire become loose
so if you do or did have a remote starter check that wire
Jan 26, 2008 at 11:57 AM
MIKEMLT
No brakes light after the change and no remote starter. Checked all the fuses, all ok!
Jan 26, 2008 at 12:07 PM
BMRFIXIT
  • 19,053 POSTS
[quote:2866226c7e="mikemlt"]No brakes light after the change and no remote starter. Checked all the fuses, all ok![/quote:2866226c7e]
this is the problem you have no power on the switch
u should have power on one of the wires at all times
and power on the other side when step on brake
check the wire if broke off at the connector check if you have power on one off the wires
Jan 26, 2008 at 1:02 PM
MIKEMLT
Thanks Guys, But a new problem is now present. I started my truck but it is locked in park gear, can't move it from the park position, no reverse, no drive just park!
Jan 27, 2008 at 9:52 PM
BMRFIXIT
  • 19,053 POSTS
[quote:eaf9d3bd0f="mikemlt"]Thanks Guys, But a new problem is now present. I started my truck but it is locked in park gear, can't move it from the park position, no reverse, no drive just park![/quote:eaf9d3bd0f]
(run a wire from the fuse box to the brake light switch for a temp fix) or
turn key to position 1
pull the shifter into neutral and then start
Jan 28, 2008 at 8:26 AM
