1998 Mercury Mountaineer
FIRESPHOTONS2
  • 1998 MERCURY MOUNTAINEER
Smells problem
1998 Mercury Mountaineer V8 All Wheel Drive Automatic
The gas tank displays corrosion and needs replacement. Does the Mountaineer tank come free without suspension or other major component removal? Any other advise on the R/R of a 1999 Mountaineer gas tank would be greatly appreciated.
Wednesday, March 25th, 2009 AT 3:28 PM
  • 109,867 POSTS
To the best of my knowledge, there are only two straps that hold it in. You will also need to remove or disconnect the down pipe (filler tube) to remove it. The wiring may need removed prior to it coming entirely out, but other than than, nothing special.
Monday, May 11th, 2009 AT 10:43 AM
