1998 Mercury Mountaineer
1998 MERCURY MOUNTAINEER
MARLONSAN
Steering problem
1998 Mercury Mountaineer 6 cyl Four Wheel Drive Automatic
when the truck is cold and i start it that power steering fluid it come out from the power steering reserve and everytime when you turn the wheel it make noise all the problem stop when the truck is hot
Nov 19, 2008 at 3:27 PM
  • 110,194 POSTS
Hi:
what a mess that must make. What I recommend first is to have the system serviced. They will remove all the fluid from the system and replace it with new and a conditionier. It that doesn't help, I recommend having the pump checked. It sounds like there may be a seal allowing the fluid to bleed back rather than where it needs to be. The seals wear out or get hard over the years. When the system warms, steel expands and seals soften.
Let me know if you have any other questions.
Dec 15, 2008 at 1:26 PM
