1997 Mercury Mountaineer No air blowing from dash board ven
1997 MERCURY MOUNTAINEER
149,000 MILES • V8 • AWD • AUTOMATIC
PORSCH1
I have an intermittant problem with air blowing from dashboard vents. Sometimes it works blowing hot air for heat and cool air for a/c. So I know the blower works ok. Most times nothing from vents or defrost or floor vents, when I turn selector to desired location. Rear controls and vents work fine. Weeks go by and it does nothing. Then one day I get in start the vehicle and I have air blowing thru front dash vents. I can't figure this out, can you help me?
May 26, 2009 at 4:00 PM
  • 110,244 POSTS
THe vents are run by vacuum. You need to check for vacuum leaks under the dash and the hood.
With the engine running, you may hear a hissing sound from a leak.
Let me know what you find.
Jun 29, 2009 at 9:16 AM
