1997 Mercury Mountaineer help me
46,000 MILES • V8 • AWD • AUTOMATIC
FUNNYFACE
my car stalled and I could not start it after that, would could be the problem? i havn't had any problems until now, does anyone know what it is?
Apr 27, 2009 at 10:09 AM
OBXAUTOMEDIC
  • 3,711 POSTS
[quote:62ebb26783="funnyface"]Electrical problem
1997 Mercury Mountaineer V8 All Wheel Drive Automatic 46000 miles
my car stalled and I could not start it after that, would could be the problem? i havn't had any problems until now, does anyone know what it is?[/quote:62ebb26783]
A more detailed description of what happened would help.
Were you driving it, were you stopped at a light/stop sign.
Does it spin over and just not start or it doesn't spin over.
Did the Engine light come on before anything happened?
Apr 27, 2009 at 10:32 AM
FUNNYFACE
i was at a light and it stalled, tried to turn it over and it turns over but will not start
Apr 27, 2009 at 10:39 AM
OBXAUTOMEDIC
  • 3,711 POSTS
[quote:3dc9560e29="funnyface"]i was at a light and it stalled, tried to turn it over and it turns over but will not start[/quote:3dc9560e29]
Is engine light on?
Can you hear the Fuel Pump run for about 3 seconds then shut down with key in the on position not start?
Check for Spark at the Plugs - Should be Bright Bluish/White.
Apr 27, 2009 at 10:43 AM
FUNNYFACE
not sure have trouble hearing what else could I check? no engine light came on it just stalled and it turns over be will not start.
Apr 27, 2009 at 10:51 AM
OBXAUTOMEDIC
  • 3,711 POSTS
[quote:0c9d06a43b="funnyface"]not sure have trouble hearing what else could I check? no engine light came on it just stalled and it turns over be will not start.[/quote:0c9d06a43b]
Ok, since there is no engine light it is most likely a fuel problem.
Need to check fuel pump relay.... It is located in the Power Distribution Box under the hood.
Check out link below for testing....
https://www.2carpros.com/how_to/how_do_i_check_a_relay.htm
If relay is good test fuel pressure.... Check out Video at the link below....
https://www.2carpros.com/car_repair_video/test_fuel_injection_pressure.htm
Apr 27, 2009 at 11:00 AM
OBXAUTOMEDIC
  • 3,711 POSTS
Also check the Fuel Inertia Shut Off Switch it is located behind passenger kick panel.
Apr 27, 2009 at 11:02 AM
