1997 Mercury Mountaineer Brake Lights Do not work.
1997 MERCURY MOUNTAINEER
150,000 MILES • V8 • 2WD • AUTOMATIC
JSRROSE1940
The gear shift will not work what could it be ?
Nov 20, 2008 at 1:32 AM
  • 110,240 POSTS
Hi:
If the shifter doesn't come out of park and the brake lights don't work, they are tied together. The brake light works in conjunction with the park lock out switch which allows the shifter to move from park. It the lights don't work, make sure the fuse is good, and if it is, replace the brake light switch.
If you have any other questions, let me know.
Dec 15, 2008 at 5:22 AM
