1997 Mercury Mountaineer
217,400 MILES • V8 • AWD • AUTOMATIC
JSHELTON50
Loud popping sounds only when taking off at a stop sign possibly from axles. Happens mostly in the morning when cold. Squeaking noises from suspension
Nov 21, 2008 at 9:31 AM
  • 110,248 POSTS
Hi:
Have the u-joints checked. If you only hear this when in 4wd, have the front CV joints checked also. The squeak you hear is most likely from dried out rubber bushings. They could be sway bar bushings, control arm bushings... Take a can of WD40 and spray one thing at a time until the sound goes away. That way you'll know where the noise is coming from.
Dec 15, 2008 at 5:20 AM
