2006 Mercury Montego rear brakes
2006 MERCURY MONTEGO
37,000 MILES • 6 CYL • AWD • AUTOMATIC
RICK BOURDON
Im doing rear brakes because of metal on metal sound on passager side rear.
I have new rotors on both sides and new Pads.
Driver side assy went OK no problems
Passienger side I can not move the caliper back in.
I have the tool recommended
Barking brake appears visually to be working oK, Gave it a tap to make sure.
Caliper tool allowed to go CCW but again it will not go Clockwise. The piston is at max out.
Jun 9, 2009 at 12:00 PM
SERVICE WRITER
  • 9,123 POSTS
Try collasping it with the bleeder open.
There may be a fluid restriction or a caliper problem on it.
Jun 9, 2009 at 12:47 PM
RICK BOURDON
I tryed cracking open the bleeder just enough to allow a little oil to flow and then tryed to screw the piston in. No luck.
I gues I could open it up more and try again
Jun 9, 2009 at 12:51 PM
SERVICE WRITER
  • 9,123 POSTS
Caliper might be bad. IT should have gone in. I hate that kind of setup for brake calipers. Engineers get a little carried away in the over designing.
Jun 9, 2009 at 12:58 PM
RICK BOURDON
Ok tryed agian.
I think Im going to wait until tomorrow and try one more time with the teen ager holding on.
If that doesnt work I guess Im going shopping for a replacement caliper. More money, just great I was hopping to save a buck. Murphy strikes again.
Thanks for your quick reply it was apprecaited
Jun 9, 2009 at 1:16 PM
SERVICE WRITER
  • 9,123 POSTS
Thanks for the donation.
If it doesn't go in with 2 of you, I'd get one.
Jun 9, 2009 at 1:26 PM
MOECAT1956
I had this problem just yesterday on a 2005 Mercury Montego. I reset the driver's side caliper by turning clockwise, but when I got to the passenger side the piston ended up fully out by going clockwise. I then turned it counterclockwise and it reset normally. I don't know if this is common to all Montego/500 but it sure worked for mine. Good luck to all.
Jun 17, 2009 at 1:25 AM
