1968 Mercury Montego Engine Not turning Over
75,000 MILES • V8 • 2WD • AUTOMATIC
SCOTLANDRUGBY15
I have a 1968 Mercury Montego 8cyl 302 V8 and i cant get the car to turn over and run. I have put in a new Battery, Alternator, solenoid, spark plugs and a starter. I also Put in fluids in the car but it is not running. What else would i need to do to get it started.
Jul 27, 2010 at 6:33 AM
  • 75,988 POSTS
Do below
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine atleast 3/16 away from ground-have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,cap and rotor,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it and keep testing
Jul 27, 2010 at 7:28 AM
