PO420 on 2000 Grand Marquis
2000 MERCURY MARQUIS
GNORTON52
I recently had the PO 420 code show up on my Grand Marquis. I've replaced the downstream O2 Sensor on bank one. It didn't fix the problem and the PO420 code showed back up. I've replaced the Cats on the left side and it still didn't fix the problem. PO420 showed back up again. I've checked the pins & connections on the CPM and all seems to be fine and I can't find any vacuum leaks anywhere . Any ideas as to what else the problem could be??
Nov 1, 2007 at 1:25 AM
[quote:e308c77ab0="mata36"]If i her the buzzing noise that means the pump turns on and if i see it througs presure that when i remove the gas line from the fuel filter, Can the pump still not work?[/quote:e308c77ab0]
If you hear the pump buzzed for that few secs-=it means it came On. If you remove the filter and see it exit-it don't mean a thing-it has to produce the correct pressure.
You need to hook-up a fuel pressure gauge to the rail and verify the pressure with and w/o the fuel pressure regulator.
Aug 17, 2007 at 10:45 PM
