No heat
LEGITIMATE007
  • 5,121 POSTS
Yes, as you probably know, several things can be on one ground, so if one thing goes bad out of that group it will mostlikely effect the others, I would also take a look at the body control module, it may have a burnt connection, as I have experienced so many times, if you havent checked all of the fuses do so and get back to me.
Thanx
Tuesday, January 16th, 2018 AT 4:08 PM (Merged)
JOHNTC70
  • 2004 MERCURY MARQUIS
  • 76,000 MILES
My car has no heat. I performed the EATC test and only code 024 showed up. Can anyone tell me what the code means?
DTC 24 Blend door short or failure-You gonna have to go visit the dealership this is a very complicated issue, involving numerous pinpoint tests-
ALEX SHAULL
I have a 1999 Mercury Grand Marquis, and I have the opposite issue. The A/C won't work, my car only blows hot air. I think that the problem is the heater control valve but I can't find it.
Wednesday, April 24th, 2019 AT 6:52 AM
KEN L
  • MASTER CERTIFIED MECHANIC
  • 48,289 POSTS
Please post your new question here, you must be logged in.
Cheers, Ken
Wednesday, April 24th, 2019 AT 11:43 AM
