Mercury GrandMarquis 1986 has little heat
1986 MERCURY MARQUIS
MESQUITE5555
My Mercury Grand marquis 1986 has little heat entering the vehicle. The blower flow seems fine. I tried to temporarily clamp the Radiator inlet hose to the Engine for just about 5 minutes and it did not change the heat temperature. What would be the best first thing to check or do?
Thank you
Jan 22, 2007 at 7:06 AM
MERLIN2021
  • 17,250 POSTS
first thing is the ant-freeze. Second is themostat. third blocked heater core, go to radiator shop and get it high pressure blown out! Do you have real good a/c? check the blend door for binding or bad servo. How is the radiator temp? Hot on top and cool on bottom is good!
Mar 5, 2007 at 6:35 AM
MESQUITE5555
[quote:391e499ef5="merlin2021"]first thing is the ant-freeze. Second is themostat. third blocked heater core, go to radiator shop and get it high pressure blown out! Do you have real good a/c? check the blend door for binding or bad servo. How is the radiator temp? Hot on top and cool on bottom is good![/quote:391e499ef5]
The AC works good. The radiator temp is actually very low. I will take these suggestions you gave into consideration and have a look tonight. Thank you.
Mar 5, 2007 at 6:47 AM
MERLIN2021
  • 17,250 POSTS
A vote would be good! If upper radiator is cold go with thermostat first the clogged radiator!
Mar 5, 2007 at 7:26 AM
