Mercury Grand Marque 2002 V8 - 160,000 miles
2002 MERCURY MARQUIS
GOLFACE7
My car seems to vibrate at different speeds. Its not tires because its a quick vibration or shaking.At first I thought it was just the road. I had the rear axels replaced and shortly after that I started noticing a vibration that felt like the road was a washboard. I did not think nothing of it then it started happening more. It feels just like you run over a washboard road for a split second sometimes longer. I would turn around and go back over the same spot to see if it was the road and I could not make it do it. My coils are going bad but that is a miss not a vibration. Any know problem with these cars that cause this.
Feb 1, 2007 at 11:56 AM
SERVICE WRITER
  • 9,123 POSTS
Would you call it a shudder? Is it more consistent at the same speed or gear shifting point?
Feb 1, 2007 at 10:07 PM
GOLFACE7
Well you might call it a shudder. Feels more like I ride over a wash board. It does not have anything to do with shifting, it is not at a shift point. it happens at different speeds. However Higher speeds are more agressive wash board feel. Today I noticed more coughing of the bad coils and feel that might have something to do with it. But again its like driving over a bunch of ripples in the road. Like the ripples to warn you you are going off the road.
Feb 2, 2007 at 1:39 PM
SERVICE WRITER
  • 9,123 POSTS
I think the starting point on this is to retreive the codes from the computer to start narrowing it down.
Feb 2, 2007 at 11:59 PM
GOLFACE7
Well took it to the dealer today and no codes listed but after driving it I had two problems. One number 6 coil bad and transmission converter going bad.
Feb 3, 2007 at 2:43 AM
SERVICE WRITER
  • 9,123 POSTS
That was why I asked about the shudder, there is a tsb on the converter for that. Glad to hear your success.
Feb 3, 2007 at 3:36 AM
