Gran Marquis Ignition Problem
RICHARD JOKE
1995 Mercury Gran Marquis
4.6L V8
197k Miles
Scenario:
Insert key into ignition turn to on position. All lights and digital console light up properly.
Attempt to start car. Engine does not crank. No "clicking" noise common with dead battery. All lights and digital console go dark. Second attempt fails due to no power at all.
After a few hours I made another attempt with the same results as above.
Replaced battery. Same results.
Inspected battery cables at terminal and at starter, found no evidence of corrosion.
After "jimmying" the battery cables on the starter side the power returned only to have it go dark again upon ignition attempt.
Have purchased new ground battery cable but would like to get a potential diagnosis from one of y'all before further repairs are attempted.
The guy at O'Reilly's said it could be the "Relay". Unsure if that would affect the digital console.
Any help appreciated.
Thanks,
Tim
Apr 5, 2007 at 5:06 AM
MERLIN2021
  • 17,250 POSTS
If the relay was bad you would not go dark! Ground cable for the battery Could do this...
Apr 5, 2007 at 8:00 AM
RICHARD JOKE
[quote:091ac4736a="merlin2021"]If the relay was bad you would not go dark! Ground cable for the battery Could do this...[/quote:091ac4736a]
Thanks for the response. I (and a couple of friends) agree that the symptoms smack of corroded battery cables but I didn't find any corrosion tell-tales.
It could still be deep in the cable I guess.
I'm going to slap on the replacement ground cable tonight.
Also, I'll shoot y'all a paypal when I'm on my home box.
Thanks,
T.
Apr 5, 2007 at 9:13 AM
RICHARD JOKE
The negative battery cable was the problem. However, I couldn't attach the new cable on the same point as the old because it was unreachable (without an engine hoist anyway). So I disconnected the old one at the battery and selected a new ground point. I chose a bolt up by the hinge for the hood. It worked perfectly.
Thanks for your help.
T.
Apr 5, 2007 at 12:41 PM
