Hello I am hoping you can give me a starting point, or hopefully an ending point. I have a 1994 mercury grand marquis, 5.0 automatic with 160k. I was driving and I stepped on the gas to the floor on acceleration which I really never did before with this car. The car went through the gears and was fine. As I came to the next light I stopped and then when I hit the gas pedal again it would not accelerate normally. I can go very very slow but if i hit the gas it will bog and stall unless I come off the gas. It runs perfect in idle and will rev up in neutral fine. I thought it was possibly the fuel pump and I changed it to no avail. Could I have broken something by hitting the pedal or is it just a coincidence it happened at that time. HELP
Nov 21, 2007 at 12:37 AM
