acceleration problem
SGTMACNYPD
Hello I am hoping you can give me a starting point, or hopefully an ending point. I have a 1994 mercury grand marquis, 5.0 automatic with 160k. I was driving and I stepped on the gas to the floor on acceleration which I really never did before with this car. The car went through the gears and was fine. As I came to the next light I stopped and then when I hit the gas pedal again it would not accelerate normally. I can go very very slow but if i hit the gas it will bog and stall unless I come off the gas. It runs perfect in idle and will rev up in neutral fine. I thought it was possibly the fuel pump and I changed it to no avail. Could I have broken something by hitting the pedal or is it just a coincidence it happened at that time. HELP
Nov 21, 2007 at 12:37 AM
BMRFIXIT
  • 19,053 POSTS
Hi fordman
under the steering column pull the cover
and on the column look for a clip with a soft very flex most the time silver color wire if you change the location of that clip that will change the indicator
good luck
Sep 13, 2007 at 4:04 PM
MERLIN2021
  • 17,250 POSTS
Fordman Town Cars don't have rack and pinion...they have reciculating ball type steering box, you will need to check the pump and box!
Sep 21, 2007 at 11:03 PM
