2002 Mercury Grand Marquis A/C Cycles
DSBILOXI
2002 Mercury Grand Marquis 4.6 liter engine 126k miles. Every year for the past three years, I have had to replace my A/C Compressor & associated parts. Thel compessors start turning off and back on irregularly. When a shop checks the freon level the required amount is always correct. Could there be another problem that new A/C compressors are only temporarly masking.
Jul 16, 2007 at 9:30 AM
2CARPRO JACK
  • 11,533 POSTS
Yes, If the pressure switch is weak it wont be able to pull the amps through it , causing it to cycle the comp off an on.Iw ould also try a different shop, they cant be serious charging you for a new comp every year for three years. A/C systems do cycle, that keeps the evaporator core (under the dash) from freezing up
Jul 17, 2007 at 12:55 AM
Suggested Repair
Check the A/C pressure switch, since a weak switch may not pass enough current and can cause irregular compressor cycling. Some cycling is normal to prevent evaporator freeze-up. Get a second opinion before replacing the compressor again.
Conversation Summary
The owner of a 2002 Mercury Grand Marquis says the A/C compressor and related parts have been replaced annually for three years because the compressor cycles on and off irregularly, although the refrigerant charge is correct. The expert says a weak pressure switch can interrupt compressor operation, notes that some cycling is normal to keep the evaporator from freezing, and recommends consulting a different shop rather than repeatedly replacing the compressor.
