ABS BRAKE SYSTEM
PHILLIP56
I HAVE A 92 MERCURY GRAND MARQUIS-4.6L ENGINE AND HAS 90,000 MILES ON IT.
WHEN BRAKING AT SLOW SPEEDS,UNDER 10MPH
THE BRAKES SEEM TO PUSH BACK. THE ABS LIGHT
DOESN'T COME ON, HOWEVER IF I DISABLE THE
ABS SYSTEM BY DISCONNECTING ONE OF THE
ABS WHEEL SENSORS THE PROBLEM GOES AWAY.
THANKYOU VERY MUCH FOR HELP
PHILLIP STREHLOW
Nov 27, 2007 at 6:13 AM
MERLIN2021
  • 17,250 POSTS
Always check the regular brake system's condition before you mess with the ABS, you might need pads, or hydraulic parts...frozen or tight calipers?
Nov 27, 2007 at 6:22 AM
