2006 Mercury Marquis a/c comes out defroster and heater ven
2006 MERCURY MARQUIS
40,000 MILES • V8 • 2WD • AUTOMATIC
LEEW54
Had the blender (blunder?) changed under warranty last year. Recently stepped on gas hard to pass and a/c began to blow from heater and defroster only. In the old days that would happen when a vacuum line came loose. Any idea?
Jun 19, 2010 at 9:03 AM
  • 110,240 POSTS
Same thing as the old days. THe vents are actuated by vacuum. When you hit the gas, the vacuum pressure drops in the engine. If there is a leak, what you described happens. Check under the dash as well as under the hood for leaks.
Let me know what you find.
Jun 21, 2010 at 4:51 PM
