2005 Mercury Marquis Steering wheel spins
90,000 MILES • V8 • 2WD • AUTOMATIC
M10504
My steering wheel just spins freely. It does not turn the steering column. If I turn it several turns to one side the horn blows. The wheel will not lock when the ignition is off and the key out. I replaced the blend door actuator and when I put the dash back together, I had no steering. The only thing close to the steering column that I touched was a nut holding the dash to the steering column.
Mike
May 13, 2010 at 5:20 AM
  • 110,248 POSTS
That is odd. Follow the steering shaft to the steering box to see if it is attached or moving.
Let me know what you find.
Jun 9, 2010 at 2:44 PM
