My steering wheel just spins freely. It does not turn the steering column. If I turn it several turns to one side the horn blows. The wheel will not lock when the ignition is off and the key out. I replaced the blend door actuator and when I put the dash back together, I had no steering. The only thing close to the steering column that I touched was a nut holding the dash to the steering column.
Mike
Mike
May 13, 2010 at 5:20 AM
