2005 Mercury Marquis Rough running at 45-50 MPH
91,000 MILES • V8 • 2WD • AUTOMATIC
MAJOR15
My problem is between 45-50 MHP the car stutters and skips when the RPM's are low. If I accelerate normal or slower the problem occurs. If I accelerate quickly the car does not miss a beat.
I have replace a fuel filter, run a bottle of techtron and spark plugs in attempts to fix this problem. I have no check engine lights.
Jun 28, 2009 at 5:09 AM
DOCFIXIT
  • 18,828 POSTS
Hi Try driving with OD off see what happens.
Let me know
Thanks for donate
Jun 28, 2009 at 6:51 AM
MAJOR15
[quote:bbbf8a9fb3="Major15"]Engine Performance problem
2005 Mercury Marquis V8 Two Wheel Drive Automatic 91000 miles
I have replace a fuel filter, run a bottle of techtron and spark plugs in attempts to fix this problem. I have no check engine lights.[/quote:bbbf8a9fb3]
I drove it with OD off and the problem did not occur. I have noticed some rough idling every 3rd or 4th stop.
Jun 29, 2009 at 9:42 AM
DOCFIXIT
  • 18,828 POSTS
O.K. shuttering coming from transmission the lock-up torque convertor and/or the solenoid. Rough idle another problem
Jun 30, 2009 at 6:23 AM
