2005 Mercury Marquis fan
70,000 MILES • V8 • 2WD • AUTOMATIC
CORONA_RCE
The fan was not working sometimes then it would work .now it does nothing. when i move the switch from low to high I can hear a click. i have checked the fuses they appear to be fine .
Mar 20, 2010 at 3:01 AM
  • 110,248 POSTS
Have you checked to see if there is power to the blower motor?
Mar 24, 2010 at 1:06 AM
CORONA_RCE
I did enough research that it pointed to the automatic temp control. i found it ,disconnected the wires and clean them . it works fine now thanks
Mar 24, 2010 at 1:29 AM
  • 110,248 POSTS
That is good to hear. At least it was a cheap repair.
Let us know if you have questions in the future, and thanks for using 2carpros.com.
Mar 24, 2010 at 3:38 AM
