2005 Mercury Marquis air is not blowing out of air condition
150,000 MILES • V8 • 2WD • AUTOMATIC
DAVANT
The air conditioner just stopped blowing air out of the vents in the dash board. I replace the Heater blend door actuator (part# 337 604-208). Still, the air will not blow out the vents.
Jun 6, 2010 at 1:38 PM
  • 110,248 POSTS
The blend door doesn't direct the air flow other than over the AC or the heater core. If the problem is getting it to blow through the vents, chances are you have a vacuum leak under the dash or the hood. Start by checking that. When checking, start the engine. You may get lucky and hear a hissing sound from where the leaks is located.
Let me know what you find.
Jun 9, 2010 at 2:15 PM
