2004 Mercury Marquis machine gun noise upon starting
32,768 MILES • V8 • 2WD • AUTOMATIC
JMMUNROE574
When I start the car in the morning, about 15 seconds later, a machine gun noise is heard. If I let it alone, it goes away after about 15-30 seconds later. If I turn off the car, the noise remains until I turn the key one position, then the noise stops. It sounds electric to me as it happens when the car engine is not running.
Dec 8, 2008 at 12:19 AM
  • 110,248 POSTS
Hi:
could it be related to the starter? Can you tell where the sound comes from?
Dec 29, 2008 at 5:44 PM
JMMUNROE574
[quote:6b5491bcaf="Jacobandnickolas"]Hi:
could it be related to the starter? Can you tell where the sound comes from?[/quote:6b5491bcaf]
New info;; It only happens when the outside temp is colder than 40 degrees!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Dec 30, 2008 at 12:20 AM
  • 110,248 POSTS
Hi:
I still think it has something to do with the starter sticking on. I recommend that you remove the starter and check it. If I'm right, the teeth on the gear will be marked. With out hearing it myself, I can't think of anything other that would make a machine gun sound other than the teeth on the starter not fully retracting from the flywheel.
Dec 30, 2008 at 3:17 AM
