AC blows hot
KRISTISWOPE
Air Conditioning problem Two Wheel Drive Automatic
my ac started blowing hot all of a sudden. We tried to put freon but it did nothing. It doesn't blow warm ...it blows hot like the heater is on. The blower works on all settings. Please help
May 15, 2010 at 9:03 AM
  • 55,673 POSTS
It sounds like you have a temperature blend door actuator that needs to be replaced. When these go out it causes the heater to come on. Here isa guide to help you see what you are in for when doing the job.
Here is what it will be like for your car (below)
Cheers, Ken
Nov 20, 2017 at 6:54 AM
VEGASCHUCK
  • 7 POSTS
2001 Mercury Marquis V8 Two Wheel Drive Automatic 100000 miles
Replaced Control Panel and Control module
When A/C is first turned on it has a knocking noise and hot air starts blowing.
Any ideas on what is causing this?
Nov 20, 2017 at 6:55 AM (Merged)
  • 75,988 POSTS
Hi vegaschuck, Welcome to 2carpros and TY for the donation
Could be the compressor is on its way out, air in the system,pressure too high,and loose support mount
VEGASCHUCK
  • 7 POSTS
All of that has been checked.....Are there sensors that operate the vent doors between hot and cold?
  • 75,988 POSTS
Could be a door problem with the air mix/blend/mode, also a vacuum and actuator or the HVAC control module itself-it needs to be open up and investigated.
VEGASCHUCK
  • 7 POSTS
Does that consist on taking the dashboard apart to get to those panels?
  • 75,988 POSTS
Yes sir-plus it can get complicated its not an easy job to do, been there don't like it-
VEGASCHUCK
  • 7 POSTS
Is removing the dashboard like on a Thunderbird or is it in pieces?
  • 75,988 POSTS
No its not the same
TYRA
https://images.2carpros.com/forum/automotive_pictures/92044_l_48ee2ef9b14b1fa8c06124bb85cbc575_2.jpg
My air conditioner just started blowing hot air a few days ago. When I went to get my oil changed the guy told me i either needed to change my air filter or he saw some cracks in my belt said i might need that replaced. I just bought a brand new cooling fan system July of 05, and I changed the filter that day. Still hot air. I was told to buy Freon...but Im a female I dont know about any of these things......PLEASE HELP ME!!
JEFFROHOTROD
  • 31 POSTS
Get a a/c recharge hose with a gauge. You can check the freon level and fill it with that,
