2003 Mercury Marquis AM/FM reception
68,000 MILES • V8 • 2WD • AUTOMATIC
JRNOVA
car radio loses FM reception. The cd player and tape deck work fine with system, but radio reception is sporadic. Radio works for months, then abruptly stops, and then comes on at intervals ranging from minutes to an hour. before going off. Then I just get statis.
Could it be the window antenna or a grounding problem. Already checked fuses.
May 21, 2008 at 8:15 AM
  • 31,937 POSTS
Hi there,
feel that it will be an internal fault with the radio, just check that the earth is ok but i feel you should have the radio tested my a radio tech.
Mark (mhpautos)
May 21, 2008 at 11:01 PM
