2003 Mercury Marquis Air conditioner
2003 MERCURY MARQUIS
97,000 MILES • V8 • 2WD • AUTOMATIC
BRUZE2002
No air blows out the front vents, only the top and bottom vents. Also when its used, the floor board under the passenger seat gets wet. I'm sure the two must be related.
Mar 2, 2010 at 7:40 AM
MERLIN2021
  • 17,250 POSTS
Run the self diagnostic test on it by turning the key to on, then press off and floor at the same time, then within 2 secs, press auto, If there is a problem a trouble code will appear on the display...To exit self test, press the BLUE, cooler button this also retains error codes, To erase codes and exit, press defrost, choose one of these before you power down the system... Test with engine at 120 degrees or more, and cabin between 40-90 degrees.Post any codes recorded here and I let you know what's defective...
As for the water, the a/c drain may be clogged. Use a piece of wire and clear the drain tube, it's on the passenger side at the bottom of the firewall.
Mar 2, 2010 at 8:04 AM
BRUZE2002
Thanks! After it ran the display read 888 just didn't look like an error code. And I cant find the drain...
may be I'd need to lift it. Thanks so much!
Mar 3, 2010 at 7:24 AM
MERLIN2021
  • 17,250 POSTS
888 means all the actuators and eatc unit are OK. You can also reach the drain inside on the passenger side, peel the rug back, and you will see a small black elbow that runs from thew case into the firewall, poke a hole downrd thru it, clear it with the wire, and some compressed air, a can of computer duster will work, Then plug the hole you poked with some RTV...
Mar 5, 2010 at 7:20 AM
