2002 Mercury Marquis shutters
122,000 MILES • V8 • 2WD • AUTOMATIC
CARLBROWN
car shutters when going uphill or under a slight load. Changed filter and transmission fluid, helped for a few days, but started again. Is getting progressively worse.
carl
Dec 3, 2008 at 12:49 AM
302ERNIE
  • 9 POSTS
change plug wires
Jan 30, 2009 at 6:29 AM
OBXAUTOMEDIC
  • 3,711 POSTS
[quote:d99da1b2aa="carlbrown"]Shakes or Wobbles problem
2002 Mercury Marquis V8 Two Wheel Drive Automatic 122000 miles
carl[/quote:d99da1b2aa]
Hi Carl,
When you changed the filter and fluid what type fluid did you use? Valvoline ATF, Mercon 5 with Shudder Protection is the fluid to use in your vehicle.
Jan 30, 2009 at 6:39 AM
