2002 Mercury Marquis GRAND MARQUIS 2002 ABS AND BRAKE LIGHT
58,000 MILES • V8 • 2WD • AUTOMATIC
2CARPRO JACK
  • 11,533 POSTS
HI, I HAVE A GRAND MARQUIS 2002, ABS AND BRAKE WARNING LIGHTS ALWAYS ON, THEY DON'T OF WHEN CAR IS RUNNING, I CHECK FUSES CONNECTORS, ALL OK, BUT WHEN IS CONNECT AN ABS SCAN TOOL THERE IS NO COMMUNICATION WITH THE ABS MODULE, I CHECK ELECTRICAL CONNECTIONS IN THE ABS MODULE CONNECTOR AND ALL OK VOLTAGES AND GROUND, I TEST THE RESISTANCE OF THE ABS WHEEL SENSOR AND ALL OK, IS THE PROBLEM THE ABS ELECTRONIC MODULE? THANKS.
RAMON V.
Apr 21, 2010 at 11:24 AM
RAMON3710
If it wont communicate, the module is usually the culprit.I would try with a different scanner just to be sure. I have had different scanners work on occasion.
Also check the fuses if one is blown it will cause this problem.
Apr 21, 2010 at 12:22 PM
