2001 Mercury Marquis Too much oil
2001 MERCURY MARQUIS
80,000 MILES • V8 • 2WD • AUTOMATIC
RAMBO3928
What could happen to my car if you drive your car if someone overfilled the oil capartmen. I'm having trouble with my check egine light and the code said it was the EGR valve and I replaced it but after 80 miles the light came back on so I was checking my fluids and my wife told me when she put oil in she went above the required marks and this is when the light came on. The car is running fine it just wont pass emissions test.
Nov 2, 2008 at 3:36 AM
BLACKOP555
  • 10,386 POSTS
could have excessive blowby and fill the air filter with oil. it could also make its way into the idle valve tps and the egr.
Nov 2, 2008 at 7:20 AM
