2001 Mercury Marquis Running out of gas
2001 MERCURY MARQUIS
150,000 MILES • V8 • 2WD • AUTOMATIC
KRWHARTON89
Hello i have a 01 grand marquis and the problem is that the car ran out of gas one day awhile back and the gauge said it had a quarter tank left so we put gas in it and it ran fine, now today the same thing happened but the gauge said it had a half of a tank left. it ran very good no problems but this is the second time this has happened so i dont know if it is the float in the tank or the sending unit fuel pump can someone please help
i just dont want to start taking stuff off the car thank you
Aug 2, 2010 at 10:23 AM
Check the fuel pressure if its within specs-could be the fuel filter/intank pick-up sock or the fuel pump
Aug 2, 2010 at 10:28 AM
KRWHARTON89
now how do i check the fuel pressure
Aug 2, 2010 at 11:08 AM
Get a repair manual and fuel pressure tester and hook it up at the fuel rail test port
Aug 2, 2010 at 7:14 PM
KRWHARTON89
Thank you, see i drove it today and it runs perfect so i think i am gonna try and replace the fuel filter first i think if it was the fuel pump it wouldnt start at all right?
Aug 3, 2010 at 8:48 AM
