The Mercury Grand Marquis has automatic temperature control. There is an itermitting problem with the blower motor. Some time it will run and sometimes it will not. When the car is started if the blower is running it will continue to run as long as the ignition is on. If it does not run it will continue so as long as ignition is on. I have been told I may need a new Electronic Automatic Temerature controll Module. Would this be the problem and if so where is this module located and what would it take to replace it?
Aug 6, 2009 at 5:07 AM
