2000 Mercury Marquis
2000 MERCURY MARQUIS
51,000 MILES • V8 • 2WD • AUTOMATIC
SETLAN23
Blower stopped running. Fuses have been checked. Next step please. I am 78, but have sons that may be able to fix it. I would take it to a dealer, but the cost for repair is a problem for me.
May 9, 2009 at 5:57 PM
BMRFIXIT
  • 19,053 POSTS
Fuses check OK !
place fan switch at high
locate blower motor right side under hood firewall
disconnect its wiring connector
check for power and check for ground if you have both motor no good
if no battery power check fuses wiring relay and ignition switch
if no ground check and suspect speed resistant relay beside blower motor
need manual CHECK IT @
https://www.2carpros.com/kpages/auto_repair_manuals.htm
May 9, 2009 at 8:32 PM
