2000 Mercury Marquis weeping head gasket
133,117 MILES • V8 • 2WD • AUTOMATIC
MARQUIS 01
i have 2000 mercury grand marquis with 133117 miles and i have a small oil leak around the cylinder head driver side front . it's doesn't run hot, no white smoke or coolant loss oil level is fine. also i was told by two auto technicians that there was no problem and that they cannot find any thing wrong. what is the problem
May 13, 2009 at 12:36 AM
MMPRINCE4000
  • 8,548 POSTS
Clean the area with a degreaser, add a small amount of dye to oil and then after a few days have the area checked with a blacklight to pinpoint leak. Could be as simple as a valve cover gasket.
May 13, 2009 at 12:56 AM
