Turn Signal blows fuses?
2000 MERCURY MARQUIS
BIGCARMAN
I put in a 15 AMP fuse and it blew once I used it on the street. Is it a wire, relay or turn signal column switch?How do I troubleshoot this issue?An answer would be greatly appreciated. Thanks.
Feb 16, 2009 at 7:19 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Most of the time it will be a bulb or bulb socket they has melted and is allow the ground to touch the power lead, I would remove all bulbs and inspect the cockets and bulb terminals. Please check out this guide to help you see what I am talking about.
https://www.2carpros.com/articles/turn-signals-not-working-blinker
and
https://www.2carpros.com/articles/no-tail-lights-exterior-running-lights-tail-lights-out
Please go over these guides and get back to us.
Mar 3, 2009 at 3:00 PM
