2000 Mercury Marquis signals and flashers
2000 MERCURY MARQUIS
80,000 MILES • V8 • 2WD • AUTOMATIC
JERRYO246
hi ,many mounths ago signals started to blink faster.looked at bulbs and they were fine .worked like this, blinking fast and slower,for a while.now they started to not work at all on and off.flashers had same results. looked for flasher relay but the the blinkers noise was comming from a light control module. checked connections,played with flashers and turn signals,but now nothing is happening no noise or lamps.also if flasher button is depressed the brake lights dont work. please advise thank you
Jan 11, 2008 at 6:44 PM
STEPHENAE
had similer problem with my 98 merc. hazard lights didnt work. ended up replacing the multifunction switch for the turn indicator. My problem solved. hope this helps
Apr 2, 2009 at 2:56 PM
