2000 Mercury Marquis Runs and Idles really rough
2000 MERCURY MARQUIS
147,000 MILES • V8 • 2WD • AUTOMATIC
STSAVIOS
The car runs really, really rough, and when it idles, sounds like its running on like 3 cylinders. It also makes a "clunking" sound. Then I took it to a shop, where they said it was misfiring on 4 cylinders, and they took to do some further testing. They then told me cylinder #1 read 0 on a compression test, and cylinder #2 was reading 50. They said I need a new engine, but that doesn't make complete sense to me... and I'm not sure what my next step should be. Does anyone have any advice?
May 27, 2010 at 7:31 AM
  • 110,244 POSTS
Did the problem start all at once? Also, if I provide directions, can you check it to make sure they are accurate?
Jun 9, 2010 at 2:30 PM
STSAVIOS
Yes, the problem did happen all of the sudden, with no prior warning. however, I am away from my car right now, and will be away from it for about 2 more months
Jun 11, 2010 at 12:16 PM
  • 110,244 POSTS
When you return, let me know and I'll walk you through some checks.
Jun 11, 2010 at 5:01 PM
