2000 Mercury Marquis Hub Bearing
2000 MERCURY MARQUIS
115,000 MILES • V8 • 2WD • AUTOMATIC
LYNGC2007
I was told I have a Hub Bearing on the front drivers side that is going bad. The mechanic said he could tighten it to make it last a little longer. Is this even possible?
Feb 5, 2009 at 3:07 AM
  • 110,240 POSTS
Hi:
If there is play in the bearing, it can be tightened, but it won't last because they shouldn't be over tightened. I recommend replacing the bearing and tightening it to the manufacturer's specs.
Feb 18, 2009 at 11:57 AM
