Engine Cooling problem
1999 Mercury Marquis V8 120000 miles
My check engine light came on then the car started running hot. I had the thermostat replaced and later that same day it ran hot again and started smoking from under the hood. When I opened the hood and removed the cover from the motor, there was a crack at the top right side and water was running out of the crack like a faucet. What should I get repaired?
Nov 30, 2008 at 3:51 AM
