1999 Mercury Marquis Valve Cover
1999 MERCURY MARQUIS
154,000 MILES • V8 • 2WD • AUTOMATIC
JACK79
i have a 99 mercury grand marquis and im trying to replace a vavle cover gasket and im able to get to all but one and thats the very back one on the driver side the electrical wires are in the way so when i get a combination wrench on it it doesnt turn because its at the cover already so how do you suggest i get it off??
Sep 18, 2010 at 3:55 AM
BLUELIGHTNIN6
  • 16,542 POSTS
will have to remove some components before you can replace that valve cover gasket. the ignition coils need disconnected, fuel injector wiring needs disconnected, move PCV tube out of the way, remove EVAP valve, disconnect harness from the valve cover and move it out of way.
Sep 18, 2010 at 5:19 AM
