1999 Mercury Marquis Intermittent Battery Light
78,350 MILES • V8 • 2WD • AUTOMATIC
RICH1947
The problem started when I replaced factory installed radio with factory built Cd player a year & half ago. The battery light started coming on intermittently. I had the alternator checked & it checked bad. I replaced and still had same problem. Eventually, the battery had to be replaced. I am on my third alternator but it does not fix the problem. I reinstalled the radio and the problem continued. To top it off, I can tap the battery light when it comes on and it goes out. I can drive for miles and it won't come on. Other days, it comes on, goes out, back on, etc.
Last symptom - the battery is reading over 14 volts most of the time even when the light comes on.
Any help would be appreciated.
Aug 22, 2008 at 2:40 PM
  • 75,988 POSTS
Belt tension okay-if so double check all connections and see below
https://images.2carpros.com/forum/automotive_pictures/12900_chrge1_1.jpg
Aug 22, 2008 at 3:03 PM
