1999 Mercury Marquis error code
CAPTAINNEL
Engine Cooling problem
1999 Mercury Marquis V8 Two Wheel Drive Automatic
got error code p1299
cylinder over temp protection active
Jun 14, 2008 at 4:39 AM
MERLIN2021
  • 17,250 POSTS
This sets when the temp in the CHT(cylinder head temp sensor) reads too high! Caused by low coolant, or a mechanical problem like a water leak. Pressure test the system and find leaks! A comon problem in these 4.6 engines was the upper intake manifold would develop a leak at the front of the engine...
Jun 14, 2008 at 4:53 AM
