1999 Mercury Marquis error code
1999 MERCURY MARQUIS
CAPTAINNEL
Engine Cooling problem
1999 Mercury Marquis V8 Two Wheel Drive Automatic
got error code p1299
cylinder over temp protection active
Jun 14, 2008 at 4:39 AM
MERLIN2021
  • 17,250 POSTS
This sets when the temp in the CHT(cylinder head temp sensor) reads too high! Caused by low coolant, or a mechanical problem like a water leak. Pressure test the system and find leaks! A comon problem in these 4.6 engines was the upper intake manifold would develop a leak at the front of the engine...
Jun 14, 2008 at 4:53 AM
